Unit has been unpluged for 3 months. No cooling either side, fan on compressor running. compressor is warm, relay will click and then shut down after 20 seconds. The capacitor has two prongs that plug into a part that has 3 prongs that plugs into the compressor. The part( not sure what it is called) with 3 prongs if shaken sounds like it may have some damage.
