GreatHawk
#1 Posted : Sunday, July 19, 2009 6:51:33 AM(UTC)
GreatHawk
My old freezer quit. Well sort of, When you turn it on it runs until it reaches the set temp. Then it turns off and dosen't turn on again, but if you turn it off and back on it will come on and run to the set temp again and so on. I think it's the control. What do you think? If it's the control where can I get one? Thanks, Greathawk
#2 Posted : Sunday, July 19, 2009 8:32:06 AM(UTC)
Measure your freezer temperature and post, you might have other problems.
GreatHawk
#3 Posted : Monday, July 20, 2009 7:43:05 AM(UTC)
GreatHawk
I turned the freezer on and it went down to -20. last night. I checked it this moning, it's still on this mornig and still running when I just checked it. It usually dosen't stay on that long. Now what? Greeathawk
GreatHawk
#4 Posted : Monday, July 20, 2009 8:05:45 AM(UTC)
GreatHawk
:confused: Turner it on and it went down to -20 last night. This morning it's at -15 and it was running still. This is the first time it has continued to run when it reach a los temp. Now what? Greathawk
#5 Posted : Monday, July 20, 2009 8:16:45 AM(UTC)
Probably a bit low on refrigerant, or the condenser has some obstruction. If condenser clean, I would get it serviced.
