Have GE side by side #”GSS22KGPC WW” that the food side is freezing up started yesterday appears that the compressor is always running also the water dispenser in door is frozen.
You might have a jammed damper door AP3420682 in the refrigerator left side. If ok and allways moves to the open position when you manually close it, you might have a bad motherboard AP4297272 or bad thermister in the fridg section. The fact that it is running constantly tells me it may just be a stuck power relay on the motherboard. If you have no meter and meter skills, best to get it serviced. You can disconnect the damper door motor cable and jam half way open the damper door. Your fridg will work fine till service person comes. Some of my customers just leave it that way, can't afford service cost! You just take a risk in case the motherboard is bad and getting worse.
Originally Posted by: richappy  You might have a jammed damper door AP3420682 in the refrigerator left side. If ok and allways moves to the open position when you manually close it, you might have a bad motherboard AP4297272 or bad thermister in the fridg section. The fact that it is running constantly tells me it may just be a stuck power relay on the motherboard. If you have no meter and meter skills, best to get it serviced. You can disconnect the damper door motor cable and jam half way open the damper door. Your fridg will work fine till service person comes. Some of my customers just leave it that way, can't afford service cost! You just take a risk in case the motherboard is bad and getting worse. have some skill with meter how do i test? thanks
Pull your schematic and check the thermistor resistance of the fridg thermistor at the motherboard. But first I would check your damper door.
Originally Posted by: richappy  Pull your schematic and check the thermistor resistance of the fridg thermistor at the motherboard. But first I would check your damper door. took damper door cover off and the door was open and i closed it by hand and it stade closed. good or bad?
Originally Posted by: nickkoko  took damper door cover off and the door was open and i closed it by hand and it stade closed. good or bad? New development looked at door now it's open, closed it again and turn off box and door closed by it self, turn back on and it opened up.
Seems that your damper door motor is working ok. What does the damper door do when you unplug refrigerator? I believe there is a spring in there that forces it shut. If ok, I would check your thermistors for out of range resistance per your schematic.Thermister resistance 65Kohm at -13 degrees 12 kohm at +40 degrees., 5kohm at 78 degrees. The thermister pins are on the motherboard upper right J1 connector. J1- 5 common 5 volts, Ji-1 fresh food thermister, Ji-2 fresh food thermister, Ji-3 freezer thermister, J1-4 evaporator thermister used to terminate defrost. The signals to the damper door are on/ off/ on/ off, no analog control signal. Frigidaire the same way, either you get voltage to open the door, or not, no voltage= door shut, voltage = door open. Makes it hard to troubleshoot!! If you monitor the damper door and find it never closes and your thermistors check out ok, I would change your motherboard AP4297272 Please go to the "sticky" GE (GSand HS) models for my article "damper motor test", you will find it as the last comment.
closes when unpluged where do i find "Please go to the "sticky" GE (GSand HS) models for my article "damper motor test", you will find it as the last comment.
Very first "sticky" in this refrigerator section, just some facts for posterity that I added, probably not relative to your problem except IF the damper motor is bad, you must replace it or the motherboard will blow, you can thank GE for that.
Originally Posted by: richappy  Very first "sticky" in this refrigerator section, just some facts for posterity that I added, probably not relative to your problem except IF the damper motor is bad, you must replace it or the motherboard will blow, you can thank GE for that. does this box have a self diagnostic test? found a GE techical service guide PUB #31-9072 per the PUB i can get it to go to test mole??? then it goes back to the temp settings does not tell me anything.:confused:
