AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer had smell of wire burning then grinding then quit
my maytag washer had a peculiar wire burning smell last week i got it to come on unloaded then i ran a cycle it made an awful grinding noise then it quit working all together can anyone tell me what might be the problem
thanks
You need to replace the main tub assembly bearing..The burning smell is coming from the belt due to bearing and it must replace too. The bearing cost is only $22.00 but to replace it will take time..call SEARS if you cannot do it.If they charge you too much like $350..better buy a new one in Costco or Home depot Appliance dept.the new one cost only $429.
im pretty good at taking things apart and putting them back together if i have some instructions and can u give an exact part number please thank you
Originally Posted by: wooley2000 im pretty good at taking things apart and putting them back together if i have some instructions and can u give an exact part number please thank you Remove the front panel. Tilt the washer back and remove the belt. Start the washer and watch the motor. Manually rotate the pump pulley in both directions to see how freely it moves. Post the results. Here are the breakdown diagrams and Replacement parts for MAYTAG MAV6000AWQ | AppliancePartsPros.comGene.
I installed new assy.main bearing. When i start running the washer theres water leaking under the tub. Also water won't stop filling the the tub..pls. help me. thanks.
Quote:...water won't stop filling the the tub... Open the control panel and check the pressure hose connection to the water level switch. Remove the front panel and check the pressure hose connection to the pressure bulb (#13 on the diagram) and the pressure bulb itself. Quote:...water leaking under the tub... Remove the front panel and pinpoint the leak. Post the results. Here are the breakdown diagrams and Replacement parts for AMANA ALW880QAW | AppliancePartsPros.comGene.
Thank you Gene for the reply..The leak is coming out only in the left portion were the the tub is seating on the body(zink/Aluminum) that connects the motor. Do you think i have to replace #9 Kit, drive bell/seal? your soonest reply is highly appreciated.
Drive bell/seal is in the center of the tub and water leak should be there too. If it's on the left then it's something else.
If it's leaking in the center then probably the hub & seal assembly (#6) is what needed. In that case the repair is going to be more expensive and it is not easy job.
The most important at this time is to find out exactly where it's leaking from.
Washer Repair
