tlpyle
#1 Posted : 16 years ago
tlpyle
I have replaced the Fixed thermastat and Heating element. When I was first checking the leads tothe fixed thermatat the lead broke off very easily and looked corroded. I checked the heating element's continutiy and it read 9.7 so I replaced it. I went ahead and changed the Thermal Fuse and still no heat. I have 240v coming in. The other two thermastats seem to have continuity. What else could be wrong?
Thanks and Frustrated!!
magician59
#2 Posted : 16 years ago
magician59
Is this consistent in all cycles?
tlpyle
#3 Posted : 16 years ago
tlpyle
Yes, I tried all cycles.
magician59
#4 Posted : 16 years ago
magician59
The thermostats and thermal fuse are wired in series with the heat element. If you'll disconnect the first wire in the series from the element to the first tstat, and the last wire out of the last tstat, See if there is continuity through all three components. You may also see continuity through the entire chain by adding the element, but it also adds quite a bit of resistance to the test.
If you do get continuity in these tests, I would suspect the timer.
tlpyle
#5 Posted : 16 years ago
tlpyle
The continuity seemed to be okay when I checked with your instructions. I have attached a picture of the power cord connections. I noticed the wire on the left was corroded and somewhat black compared to the other two. I traced the wire (it is black) and it goes to the timer.
Maybe a stretch but I thought it may be worth a shot. I have not priced the power cord yet.
Your thoughts?
tlpyle attached the following image(s):
magician59
#6 Posted : 16 years ago
magician59
You should be getting 220-240VAC between the left and right connectors. You should get 118-120VAC between either of the outside connectors and the middle one. Unplug the core and check for continuity along each individual leg of the cord.
Dryer has no heat. (Dryer Repair)
by Goatman48 7 years ago
my roper dryer has no heat (Dryer Repair)
by vanj333 13 years ago
Dryer has NO heat, but runs (Dryer Repair)
by MCH_STL 13 years ago
maytag dryer HAS NO HEAT! (Dryer Repair)
by gtopij 13 years ago
Frigidaire Dryer Has No Heat (Dryer Repair)
by moody9207 13 years ago
electric dryer has no heat (Dryer Repair)
by Anthony Cetani 13 years ago
Dryer has no heat (Dryer Repair)
by marcustheman 13 years ago
by Ken Louie 13 years ago
Frigidare Dryer has no heat and timer does not work (Dryer Repair)
by qt3110 13 years ago
by slowey 14 years ago
dryer has no heat & wont run (Dryer Repair)
by K Graber 14 years ago
by tbtpounce 14 years ago
Gas Dryer has no heat (Dryer Repair)
by bmpaul 15 years ago
by slim10 15 years ago
HELP!!! Dryer has no heat (Dryer Repair)
by quinn9829 15 years ago
