Lisa Minor
#1 Posted : Thursday, July 16, 2009 9:16:38 AM(UTC)
Lisa Minor
The plastic tip underneath the starter control on the front panel broke off. How difficult would it be for me to replace this part myself?
#2 Posted : Thursday, July 16, 2009 5:18:40 PM(UTC)
The model number you posted does not come up. The closest model number I found is Model LER331DS0 . Verify and repost the model number.
I'm afraid I did not clear which part you are talking about. Can you refer to the part using numbers form the diagram? Replacement parts for FRG LER331DS0 | AppliancePartsPros.com
Housing wheel loose on frigidare dryer (Dryer Repair)
by Kcsrugs 10/29/2016 9:17:23 AM(UTC)
Frigidare Dryer has no heat and timer does not work (Dryer Repair)
by qt3110 9/19/2011 9:05:10 PM(UTC)
Frigidare Dryer will only work on low heat (Dryer Repair)
by TavisHarvard 4/2/2011 3:19:10 PM(UTC)
Frigidare Dryer Spin Not Continous (Dryer Repair)
by WARRIOR 1/9/2011 2:02:12 AM(UTC)
Frigidare Dryer not heating but does spin (Dryer Repair)
by George120 12/9/2010 12:36:09 PM(UTC)
Frigidare dryer won't turn off (Dryer Repair)
by garysteven 9/28/2009 2:53:36 PM(UTC)
Kenmore/frigidare dryer no heat (Dryer Repair)
by johny 2/22/2009 4:10:55 PM(UTC)
Frigidare dryer with no heat (Dryer Repair)
by bit1001001 10/29/2007 6:39:52 AM(UTC)
