TavisHarvard
#1 Posted : Saturday, April 2, 2011 3:19:10 PM(UTC)
TavisHarvard
The dryer will only work on low heat. It does dry the clothes but it takes twice as long. If I change the heat setting to medium or high a "dr" flashes in the display window and the dryer will not start. I have tried all settings (Heavy duty,normal,medium,delicate,etc). The dryer will only run on the low heat setting.:confused::confused::confused:
sidfink43
#2 Posted : Monday, April 4, 2011 4:30:47 PM(UTC)
sidfink43
Look inside the rear service panel for tech notes that are on the right hand wall. They should give you some diagnostic testing procedures.
