lt3
#1 Posted : Thursday, January 3, 2008 9:19:00 AM(UTC)
lt3
i have a whirpool that i replaced the high limit thermostat and it still isn't drying like it use too ? next to replacing the dryer where / what should i try next?
#2 Posted : Thursday, January 3, 2008 7:19:14 PM(UTC)
If it takes longer time to dry but there is warm inside the dryer then the problem is a clogged vent outside the dryer.
Disconnect the vent hose from the dryer and run a couple loads. If you see better time, then the vent has to be cleaned.
- Here are the break down diagrams for the Whirlpool dryer Model LG6151XSW0
Good luck.
lt3
#3 Posted : Friday, January 4, 2008 3:37:31 AM(UTC)
lt3
gene thanks for the responce . i changed the dryer hose when i changed out the high temp sensor thing , any ideas if it might be another sensor ?
okbobcats
#4 Posted : Friday, January 4, 2008 4:23:39 AM(UTC)
okbobcats
It could be part #ap3116922 page 1 item 8. This part controls the heat in your dryer. Does your dryer get hot or does it just get warm? you could also have some trouble with your burner.
#5 Posted : Friday, January 4, 2008 7:34:50 AM(UTC)
There is a vent inside the wall and not only the vent hose.
This vent causing the air flow restriction more often.
That's why I recommended to disconnect the hose and run a couple of loads without the hose.
lt3
#6 Posted : Friday, January 4, 2008 9:38:45 AM(UTC)
lt3
thank you very much ! i promise not to tell my wifee where i figured out how to fix the dryer she really wanted a new one
Dryer not drying enough (Dryer Repair)
by freddyfrenchy 2/2/2011 5:09:29 PM(UTC)
Dryer Not Drying Enough - Kkenmore Elite (Dryer Repair)
by ray peralez 4/16/2010 11:12:17 AM(UTC)
