Althea
#1 Posted : Saturday, July 11, 2009 7:18:43 AM(UTC)
Althea
my dryer starts out heating normally ,after inital start up will not continue to heat. any ideas?
sidfink43
#2 Posted : Monday, July 13, 2009 5:57:13 AM(UTC)
sidfink43
Hi Althea
Sounds like the problem is in your gas burner system. I do not work on gas appliances, but if you look at the posts on gas dryers on this Forum you will see that most of the problems like yours are the result of bad coils.
I would review those posts, and if you believe you have a similar problem I would replace the coils and see if that does not fix the problem, since it is an easy and inexpensive repair.
Good luck
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 3/2/2024 3:42:02 PM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Kenmore Dryer spinning cold air nonstop until the door is open (Dryer Repair)
by Guest 5/15/2023 10:22:27 AM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Kenmore dryer issue when heat is on (Dryer Repair)
by Guest 2/2/2023 2:17:08 PM(UTC)
Kenmore Dryer Model:86984110 (Dryer Repair)
by CarolynC143 10/23/2022 5:00:36 AM(UTC)
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 5/5/2022 8:17:09 PM(UTC)
Repair manual for Kenmore dryer model 110.85081401 (Washer Repair)
by Guest 5/5/2022 2:29:52 PM(UTC)
kenmore dryer wiring (General Talk)
by epyveras 3/24/2022 7:04:26 AM(UTC)
KENMORE DRYER WIRING 796.813 (Dryer Repair)
by Guest 3/24/2022 7:00:58 AM(UTC)
Kenmore Dryer Model 110.76752500 Parts (Dryer Repair)
by redknitter 2/23/2022 7:24:03 AM(UTC)
kenmore dryer powers up with lights on, push start and it chirps and that is all (Dryer Repair)
by Guest 10/14/2021 7:53:03 PM(UTC)
Kenmore Dryer 41790052990 (Dryer Repair)
by Guest 3/26/2021 4:59:53 PM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
