Just a few days before the dryer stopped working altogether, it started stopping in the middle of the cycle. The light is on in the dryer but that is the most it will do. Thanks Michele
Hi Michey
Since your light is coming on you have power to the machine, but check the connection block with a meter anyway to make certain you have 240 v coming to the dryer.
Take off the back of the dryer and check the thermostats and thermnal fuse for continuity.
If they check out, test the door switch to make sure it is ok.
You should find the problem with those checks, but if not, you may have a problem with the timer or the motor.
Good luck, let us know what you find out.
