AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
The water dispenser leaks continually, had to cut the water off to stop it
Hi, The water dispenser on the front of the refrigerator water flows out of it continually instead when you put the cup under it. I don't know what is broken. When you put the cup under it and push the lever and take the cup back it continues to flow non-stop.
Thank you,
Willie
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
