Willie Jones
#1 Posted : Sunday, July 12, 2009 4:32:26 PM(UTC)
Willie Jones
The water dispenser on the front of the refrigerator water flows out of it continually instead when you put the cup under it. I don't know what is broken. When you put the cup under it and push the lever and take the cup back it continues to flow non-stop.
Thank you,
Willie
woodchuckie
#2 Posted : Sunday, July 12, 2009 5:28:44 PM(UTC)
woodchuckie
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
