fftpc
#1 Posted : Wednesday, August 8, 2007 3:08:44 PM(UTC)
fftpc
I have a major leak whose location appears between the head of one of the two bolts that connects the oven control valve to the manifold. Is there a kit available to fix this problem? I suspect that I just need a new gasket and/or retighten the bolt. Is this correct and if so, where can I get a gasket? Someone told me the bolt should be treated with pipe compound before it is tightend; is this true.
Any ideas you can give me would be great. My stove is in a remote site and its leak forced me to eat peanut butter rather than steak last time I was at the cabin.
Admin / APP Team
#2 Posted : Wednesday, August 8, 2007 3:20:53 PM(UTC)
Admin / APP Team
Rank: Administration
Groups:
By oven control valve I'm assuming you mean the oven thermostat, right?
Open this diagram, look at #2 - there are 3 different thermostats for this model. Which of the three looks like the old one? Let me know...
If you can provide any numbers off the old thermostat, that would be even better.
fftpc
#3 Posted : Wednesday, August 8, 2007 4:47:51 PM(UTC)
fftpc
You are correct- I am talking about the thermostate. I am working off memory but the middle picture (AP381358) seems most familiar. I suspect, however, that I am going to have to make a trip to the "bush" and bring it back into town. At that point I will get back to you unless you think you can still help me with the limited knowledge I have. Regardless, I sure appreciate your quick response!
Tom Clausen
gas leaking from burners and oven cavity (Oven Repair (including Ranges and Cooktops))
by MarisaCKD 6/2/2020 6:45:23 AM(UTC)
Roper/Whirlpool dryer gas leak (Dryer Repair)
by STLDIYer 7/20/2017 12:47:35 PM(UTC)
Gas Leak AFTER on for 15 minuets (Oven Repair (including Ranges and Cooktops))
by therealfleen 1/16/2015 9:48:47 AM(UTC)
Gas leak smell from oven (Oven Repair (including Ranges and Cooktops))
by Aguilareagle1 11/16/2013 11:46:06 AM(UTC)
gas leak (Oven Repair (including Ranges and Cooktops))
by michellejacobson@email.co 12/12/2011 10:10:22 AM(UTC)
Gas leaking when oven is shut off (Oven Repair (including Ranges and Cooktops))
by charlieq3 3/24/2011 10:04:10 AM(UTC)
gas leaks from base of burner (Oven Repair (including Ranges and Cooktops))
by Cyprien 6/24/2010 8:59:36 AM(UTC)
My oven wont ignite after I tightened gas leaking connector (Oven Repair (including Ranges and Cooktops))
by raminla 6/2/2010 12:14:35 PM(UTC)
gas leak from valve when dryer is off (Dryer Repair)
by drainpros 4/19/2010 8:14:56 AM(UTC)
Gas leak (Oven Repair (including Ranges and Cooktops))
by paris795 11/23/2009 8:41:56 AM(UTC)
small gas leak/smell of gas (Oven Repair (including Ranges and Cooktops))
by jmarc 10/7/2009 12:10:44 PM(UTC)
Kenmore gas stove W/ gas leak (Oven Repair (including Ranges and Cooktops))
by Snake 7/22/2009 12:50:33 AM(UTC)
Magic Chef 3468xva gas leak (Oven Repair (including Ranges and Cooktops))
by indianfan79 6/30/2009 12:05:07 PM(UTC)
gas leaking oven (Oven Repair (including Ranges and Cooktops))
by steinle 6/29/2009 8:30:26 AM(UTC)
gas leaking after installing new glow igniter (Oven Repair (including Ranges and Cooktops))
by schimickn 6/27/2009 5:56:54 AM(UTC)
