WHEN I PRESS THE "BAKE" pad on oven, the temperature setting is too faint to read it...
Originally Posted by: Dan O.  The time display is visible (altho I don't think its as bright as it used to be) the temperature setting is no more/no less visible when I press "Bake"
Quote:the temperature setting is no more/no less visible when I press "Bake" Is it different than the time display? If both are similar, the electronic control is likely the cause. If the time/temperature illumination is different, I don't know what could cause that but I can't see it being anything other than the control either. JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~
