csmith5716
#1 Posted : Wednesday, July 8, 2009 11:08:33 AM(UTC)
csmith5716
WHEN I PRESS THE "BAKE" pad on oven, the temperature setting is too faint to read it...
Dan O.
#2 Posted : Wednesday, July 8, 2009 1:44:39 PM(UTC)
Dan O.
Quote:
WHEN I PRESS THE "BAKE"...
Is the display always too faint or just when you press bake? If always, there is likely a problem in the electronic control itself.
LINK > FEB756CESA Electronic Control
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
csmith5716
#3 Posted : Wednesday, July 8, 2009 2:35:35 PM(UTC)
csmith5716
JMO
Dan O.
=D~~~~~~
The time display is visible (altho I don't think its as bright as it used to be) the temperature setting is no more/no less visible when I press "Bake"
Dan O.
#4 Posted : Thursday, July 9, 2009 11:17:29 AM(UTC)
Dan O.
Is it different than the time display? If both are similar, the electronic control is likely the cause. If the time/temperature illumination is different, I don't know what could cause that but I can't see it being anything other than the control either.
JMO
Dan O.
=D~~~~~~
