rryker1971
#1 Posted : Wednesday, July 8, 2009 4:27:53 PM(UTC)
rryker1971
I replaced the thermal fuse. Now it works but no heat.
What could be wrong?
kayakcrzy
#2 Posted : Thursday, July 9, 2009 4:45:02 AM(UTC)
kayakcrzy
Well it will either be the element or the thermal fuse mounted on the element assembly. I would go with the element, which probably blew the fuse. Also flip the dryer breaker a few times to be sure the dryer is getting full power. Tom ApplianceEducator.com
cvex4370B Jenn Air Grill element does not heat up (Oven Repair (including Ranges and Cooktops))
by Guest 4/13/2021 8:44:32 AM(UTC)
Microwave does not Heat Food (Microwave Repair)
by newatappliancerepair 11/10/2016 10:53:37 AM(UTC)
Lower oven heating element does not heat up (Oven Repair (including Ranges and Cooktops))
by msterren 4/16/2016 8:45:48 AM(UTC)
Oven does not heat to temperature set (Oven Repair (including Ranges and Cooktops))
by lauract 11/13/2015 12:53:01 PM(UTC)
GE profile harmony gas dryer does not heat (Dryer Repair)
by wonder88 8/30/2015 2:22:05 PM(UTC)
Oven does not heat up (Oven Repair (including Ranges and Cooktops))
by drpflyers 7/21/2015 1:32:17 PM(UTC)
Dryer runs but does not heat (Dryer Repair)
by blm1964 2/13/2015 8:54:47 PM(UTC)
Lower oven element does not heat (Oven Repair (including Ranges and Cooktops))
by throopwh 1/21/2015 6:26:46 PM(UTC)
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Dryer does not heat anymore (Dryer Repair)
by yellowsir 2/28/2014 8:09:39 AM(UTC)
Oven does not heat past 270 (Oven Repair (including Ranges and Cooktops))
by frostyj50 11/18/2013 6:59:17 PM(UTC)
Oven will overheat/broil burner goes bright red/bake burner does not heat (Oven Repair (including Ranges and Cooktops))
by Mitch29 11/14/2013 10:45:29 AM(UTC)
Microwave does not heat (Microwave Repair)
by flynkites 2/4/2013 6:28:06 AM(UTC)
Dryer does not heat (gas) (Dryer Repair)
by SCOTT4 2/2/2013 7:47:15 AM(UTC)
dryer runs but does not heat (Dryer Repair)
by rdrobertson15@yahoo.com 12/2/2012 7:10:03 AM(UTC)
