ddnguyen06
#1 Posted : Wednesday, July 8, 2009 3:10:40 PM(UTC)
ddnguyen06
My electric dryer have no heat. I did check the heating elements and they are goods. please help.
#2 Posted : Thursday, July 9, 2009 3:19:44 AM(UTC)
Probably a bad thermal fuse located near the top of the heater assy. Just take the wires off, short them, and see if you have heat. If so, order the kit
AP3094244 comes with the fuse and overload thermostat.
ddnguyen06
#3 Posted : Thursday, July 9, 2009 8:03:38 AM(UTC)
ddnguyen06
I checked all the thermostat and thermal fuse are working fine and the continuity are goods. motor keep running even i open the dryer door it does not stop.
#4 Posted : Thursday, July 9, 2009 10:29:42 AM(UTC)
Check the power in the back, should be 230 volts. If ok, check the timer contacts for heat. Usually a heavy gauge yellow and black wires.
heating problems, no heat (Dryer Repair)
by ddnguyen06 7/8/2009 3:04:42 PM(UTC)
by ddnguyen06 7/8/2009 3:01:02 PM(UTC)
