how do i remove the front burner on my stove it looks as though all the burners are one piece with the tubes and valves. my front burner has started burning from the bottom of it and i dont want to blow any thing up it is the only one that will turn in circles which leads me to believe that it has burned out from the botttom
Quote:it looks as though all the burners are one piece with the tubes and valves. The tube to the burner looks to just fit over the back end of the burner valve. There looks to be something in between called a "burner insert" but I am not familiar with that particular set up and don't know its purpose. JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~
