Maytag washer 3 years old makes racing sound in spin cycle
You probably have a bad pump AP4373022, just tilt washer back, remove belt and check pump for bad bearings.
Pump seems to be solid but the thrust bearing has a little wiggle is that typical?
You may have bad tub bearings and seals. Look below the tub for water signs. Post results
