steiner
#1 Posted : Tuesday, July 7, 2009 7:24:48 PM(UTC)
steiner
Maytag washer 3 years old makes racing sound in spin cycle
#2 Posted : Wednesday, July 8, 2009 3:05:30 AM(UTC)
You probably have a bad pump AP4373022, just tilt washer back, remove belt and check pump for bad bearings.
steiner
#3 Posted : Wednesday, July 8, 2009 7:35:29 AM(UTC)
steiner
Pump seems to be solid but the thrust bearing has a little wiggle is that typical?
#4 Posted : Wednesday, July 8, 2009 11:02:12 AM(UTC)
You may have bad tub bearings and seals. Look below the tub for water signs.
Post results
