3 Pages123>
bdubois
#1 Posted : Monday, July 6, 2009 8:21:42 AM(UTC)
bdubois
I checked the line voltage and am getting 220v. I checked the voltage at the starter switch am getting 110.
#2 Posted : Monday, July 6, 2009 6:22:04 PM(UTC)
Quote:
...dryer won't start-just hums when I push the start button...
Sounds like the motor has gone bad.
The part number for the motor is AP3094245
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL WED5300SQ0 | AppliancePartsPros.com
bdubois
#3 Posted : Tuesday, July 7, 2009 7:23:47 AM(UTC)
bdubois
Gene, thanks for the reply. Any hints on getting the motor out. Looks like I may have to remove the drum first.
#4 Posted : Tuesday, July 7, 2009 4:32:22 PM(UTC)
Yes, you do have to disassemble the dryer to access the motor.
This Service manual might help even if it's not exactly for your model.
bdubois
#5 Posted : Tuesday, July 7, 2009 7:13:40 PM(UTC)
bdubois
Gene, thank you very much. I just wish it would have been a switch instead of the motor. The service manual helps a great deal.
Barry
#6 Posted : Tuesday, July 7, 2009 9:14:22 PM(UTC)
You are welcome Barry. Keep us posted.
bdubois
#7 Posted : Thursday, July 9, 2009 8:26:18 AM(UTC)
bdubois
Gene, I wanted to let you know that I contacted Whirlpool and they are going to send me a motor at no charge. That's some pretty good cuistomer service on their part.
Thanks again!
Barry
#8 Posted : Thursday, July 9, 2009 6:10:23 PM(UTC)
Barry,
I'm glad to hear it. Surprise!
ronamer
#9 Posted : Wednesday, September 16, 2009 11:27:33 PM(UTC)
ronamer
Barry,
Gene,
I am relatively knowlegable in the "applied sciences" of most things. I am curious, how can a motor be the problem when the motor works? some form of start-up ballast issue? me, I would have guessed a relay or something. if it just hummed, and nothing turned, I would say a belt. looks like I can learn a thing or two from you, I hope. can you give me the reason this would happen? also, since they are sending him a new motor gratis, I am thinking they will be top of my list on my next new purchase. to me, customer service is the key to ownership. someone that stands behind their product. thanks to both of you for teaching me some new things.
#10 Posted : Thursday, September 17, 2009 3:06:57 PM(UTC)
A regular simple motor has two windings: start and run, and centrifugal switch. Start winding has a higher torque to start a rotor movement. Power comes to both windings when you push start button. As soon as a rotor got to its normal speed, centrifugal switch interrupts power to start winding while run winding still has it.
If there is something wrong with start winding then rotor can not start rotation because run winding does not have enough torque for it, but because it's powered up - it makes a humming noise.
3 Pages123>
