deertick
#1 Posted : Wednesday, January 2, 2008 4:02:21 PM(UTC)
deertick
Runs thru cycle "normal" except does not fill or drain (just uses water left in tub). Float free of obstructions and switch is heard while manually actuating. Hoses are clear. Motor / pump does not turn on to fill/drain, but does "wash". HELP!!!!
#2 Posted : Wednesday, January 2, 2008 5:09:01 PM(UTC)
Assuming the water valve under the sink is open, I would start with the water inlet valve.
If water is coming to the dishwasher, check for 120V coming to the water inlet valve when the timer calls for water.
If there is 120V, then replace the water inlet valve.
If there is no 120V, then check wires. If there is nothing wrong - replace the timer.
- The part number for the water inlet valve is AP3790911
- The part number for the timer is AP3214619
Good luck.
