:eek: MY dryer when clothes in it,makes a sliding/scraping noise.when stopped and restarted it makes a "jerk" in the back and starts to make noise again after awhile.It still drys but gets very hot in the top rt hand corner.Help!!!
Quote:...It still drys but gets very hot in the top rt hand corner... Most likely the vent is clogged. Check it all the way to the outlet. Quote:...when stopped and restarted it makes a "jerk" in the back and starts to make noise again after awhile... Most likely the rear bearing is worn out. You have to remove the front panel and the drum to access the bearing. Check all parts and post the results if you need the correct part numbers. Gene.
