My roper dryer was not heating so i replaced the heating element and it worked for 2 loads of laundry. Now it won't start at all.
At the same time i replaced the Thermal cut-off when i replaced the heating element.
I Have A Roper 2 And Im Having The Same Problem Did You Get It Fixed And What Was The Problem?
Originally Posted by: rryker1971  My roper dryer was not heating so i replaced the heating element and it worked for 2 loads of laundry. Now it won't start at all. Check the thermal fuse (#23 on the diagram) for continuity. Very likely the vent line and/or the air ducts inside the dryer are clogged up, causing the dryer to overheat. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RED4100SQ0 | AppliancePartsPros.comGene.
Originally Posted by: offshorextreme  I Have A Roper 2 And Im Having The Same Problem Did You Get It Fixed And What Was The Problem? The complete model number of the dryer and more specific description on the problem might help others to help you. Gene.
i replaced the thermal fuse now it starts but no heat.
