rryker1971
#1 Posted : Monday, July 6, 2009 5:25:04 AM(UTC)
rryker1971
My roper dryer was not heating so i replaced the heating element and it worked for 2 loads of laundry. Now it won't start at all.
rryker1971
#2 Posted : Monday, July 6, 2009 5:29:22 AM(UTC)
rryker1971
At the same time i replaced the Thermal cut-off when i replaced the heating element.
offshorextreme
#3 Posted : Monday, July 6, 2009 6:45:29 AM(UTC)
offshorextreme
I Have A Roper 2 And Im Having The Same Problem Did You Get It Fixed And What Was The Problem?
#4 Posted : Monday, July 6, 2009 1:00:57 PM(UTC)
Check the thermal fuse (#23 on the diagram) for continuity. Very likely the vent line and/or the air ducts inside the dryer are clogged up, causing the dryer to overheat.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RED4100SQ0 | AppliancePartsPros.com
#5 Posted : Monday, July 6, 2009 1:02:10 PM(UTC)
The complete model number of the dryer and more specific description on the problem might help others to help you.
rryker1971
#6 Posted : Wednesday, July 8, 2009 2:33:36 PM(UTC)
rryker1971
i replaced the thermal fuse now it starts but no heat.
