3 Pages123>
bubbastockton
#1 Posted : Tuesday, January 1, 2008 1:02:21 PM(UTC)
bubbastockton
My oven will not work. The error code is F 10. What would the problem be. Thanks
#2 Posted : Wednesday, January 2, 2008 10:24:17 AM(UTC)
The "F10" error code means the runaway temperature.
Check the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control).
It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong, check the resistance at the oven probe plug.
If the reading is wrong - replace the oven temperature probe.
If the readings right - check the wire harness from the temperature probe to the EOC.
If there is nothing wrong with the oven temperature probe, then replace the EOC. You can use the old overlay or replace it too.
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the black overlay is AP3778486
Good luck.
bubbastockton
#3 Posted : Wednesday, January 2, 2008 12:42:53 PM(UTC)
bubbastockton
Will check the oven shortly. Thanks
#4 Posted : Wednesday, January 2, 2008 12:47:56 PM(UTC)
Keep me updated, please.
bubbastockton
#5 Posted : Wednesday, January 2, 2008 2:31:18 PM(UTC)
bubbastockton
I just checked this oven and the resistance was about 1040-1050 at the terminal block and the probe. Does that mean the probe was good? All the wiring looks fine. Is the only other thing it could be is the EOC? Thanks so much for your help!!
#6 Posted : Wednesday, January 2, 2008 2:56:23 PM(UTC)
Yes, in such situation the only thing it could be is the EOC.
bubbastockton
#7 Posted : Wednesday, January 9, 2008 1:38:44 PM(UTC)
bubbastockton
replaced the EOC today and it fixed the problem. Thanks for all your help:) :) :D
#8 Posted : Wednesday, January 9, 2008 3:56:27 PM(UTC)
I'm glad you were able to fix it.
Best regards.
cjtyo
#9 Posted : Wednesday, July 2, 2008 10:22:39 AM(UTC)
cjtyo
Gene,
I have the same F 10 issue going on with my 790.961* model Kenmore electric range with glass cooktop.
My question for you is where these parts you say to test are located in my oven - the manual is less than helpful for locating operating parts.
So, where is "the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control)"?
Where is "the oven probe plug" if I have to test that too?
Where is "the wire harness from the temperature probe to the EOC"?
Thank you!
C
#10 Posted : Wednesday, July 2, 2008 11:00:56 AM(UTC)
cjtyo,
In order to provide most accurate advise we need the complete model number of the range.
Guest (7)
gas range fault F 10 (Oven Repair (including Ranges and Cooktops))
by ddlong 9/13/2010 9:32:25 AM(UTC)
Can I use 20w bulbs instead of 10w to light cooktop? (Microwave Repair)
by Daniel J 2/28/2010 4:22:05 PM(UTC)
LG Electric dryer will not shut off 10 seconds after starting (Dryer Repair)
by miketieman 1/8/2010 3:02:54 PM(UTC)
Kenmore Wall Oven F 10 Fault (Oven Repair (including Ranges and Cooktops))
by Bigben 1/18/2009 10:46:53 AM(UTC)
Water Heater Relays click on/off 10-20 times (General Talk)
by markwrightjohnson 11/16/2008 11:44:23 AM(UTC)
Oven temp off 100 degrees (Oven Repair (including Ranges and Cooktops))
by S Brown 10/30/2008 6:44:37 AM(UTC)
3 Pages123>
