wildbill58
#1 Posted : Thursday, July 2, 2009 7:08:52 PM(UTC)
wildbill58
CLEANING LIGHT STILL BLINKS ON DISH WASHER AND WILL NOT GO THROUGH A WHOLE CYCLE. REPLACED BOTH DOOR SWITCHES! NOW WHAT ? SOME ONE HELP !! :mad:
#2 Posted : Friday, July 3, 2009 7:05:15 PM(UTC)
This problem explained in the Whirlpool Technical Bulletin.
Try to reset the control board by initializing the service diagnostic cycle. Check the dishwasher tech sheet for the correct cycle sequence.
If it will happen again then you have to check the heating circuit for a faulty part(s).
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU2400XTPB3 | AppliancePartsPros.com
wildbill58
#3 Posted : Saturday, July 4, 2009 6:03:12 AM(UTC)
wildbill58
Thank you, Gene I pull my dishwasher out, and found that I have bad heat element and I ordered one. I think this is going to fix my dishwasher, I'am hopeing that I'll get my heat element by monday.:) again, thank you for your help!!! If this does;nt work I'll be back here again.
#4 Posted : Sunday, July 5, 2009 4:19:03 PM(UTC)
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
