hello
i am assuming a belt is worn on our top loaded washer. It spins, but clothes are very damp after wash. Can I get the belt at any Whirlpool retail store, such as Sears?
Are they easy to replace?
thank you
this us a direct drive washer .no belt .may be clutch problem, or drive block worn
You might have dragging brake shoes, just check the motor current, should be around 8- 9 amps. One way to confirm is to pull pump and motor and turn tranny coupler clockwise. If hard to turn spin basket=dragging brake shoes. Please post results.
