ericvt.bateman
#1 Posted : Thursday, July 2, 2009 7:28:19 AM(UTC)
ericvt.bateman
replaced HV board, control board (behind the keypad and the keypad on a KBFL25ETSS 00 and the freezer temp display shows "PEO" and the refrig temp display shows "000" code inside refrigerator is 0801 - how do I get the unit running again?
#2 Posted : Thursday, July 2, 2009 7:55:31 AM(UTC)
Look for your service data sheet under the kick panel, should have a computer reset procedure. Also, your info supplied with the parts may have it.
ericvt.bateman
#3 Posted : Thursday, July 2, 2009 9:46:21 AM(UTC)
ericvt.bateman
I found the service data sheet but the keypad does not respond - no sound when you press a key. Is there something else I am missing?
#4 Posted : Thursday, July 2, 2009 10:41:55 AM(UTC)
Check all your connectors, sometimes a pin will come loose.
Guest (4)
