2 Pages12>
jivery
#1 Posted : Friday, May 22, 2009 11:10:29 AM(UTC)
jivery
After the self cleaning cycle heating elements does not heat. However, the panel works (clock, timer) Husband perform continuity check on elements an the result was positive for continuity. Also tested resistance of thermostat reading was well within range. Is there any other test that has to be performed to determine where the problem is? Also what part is needed to fix the problem?
#2 Posted : Friday, May 22, 2009 1:58:59 PM(UTC)
Most likely the problem is a bad (open) thermal fuse on the back of the oven (#37 on the diagram).
- The part number for the thermal fuse is AP3885687
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RBS305PDB16 | AppliancePartsPros.com
rescue_dog01
#3 Posted : Tuesday, June 9, 2009 6:56:26 AM(UTC)
rescue_dog01
Element does not glow red at all no matter it is preheat, bake or whatever. i have switched the range breaker off/on. Found this article as a possible repair: http://forum.doityourself.com/k...after-self-cleaning.html
I have not tried all suggestions. Wanted to post issue here. Current status: I have oven pulled out of cabinet and ready to dive in!
Thank you
Dan O.
#4 Posted : Tuesday, June 9, 2009 12:13:03 PM(UTC)
Dan O.
rescue_dog01, are you the original poster?
If not you should start a new message of your own with your symptoms/questions and be sure to include the appliance's model number to enable us to look it up to see what appliance design you're dealing with.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
RockDawg
#5 Posted : Monday, June 29, 2009 6:05:08 PM(UTC)
RockDawg
Gene,
I was having the same problem with by RBS305PDB16 after using the self-cleaning cycle for the first time. Also besides not heating, the temperature up button would not function in any mode nor the Cancel Button (had to flip fuse.), oven light button (light works though), or timer.
I replaced the thermal fuse tonight with the part you stated. Now when I hit the bake button, it will preheat to 350 degrees (some progress):) but I still cannot get the above mentioned buttons to work. I can use the Timed Bake button and set it to 1 minute to get it to shut off. I tried cycling the power and even locking/unlocking the keypad but nothing.
Is this all typically part of the same problem/cause or is it multiple problems? Any suggestions?
(in reference to Dan O's note above, I will start a new topic if needed; but that was one of my symptoms and my model so I thought this was on-topic.)
Chuck
#6 Posted : Monday, June 29, 2009 7:33:00 PM(UTC)
Hi Chuck,
Sounds like the key panel has gone bad. The correction is to replace the control panel. If you need the correct part number then post the color of it.
RockDawg
#7 Posted : Monday, June 29, 2009 7:36:08 PM(UTC)
RockDawg
Hi Chuck,
Black.
Are we talking the membrane layer or the circuit board layer (I saw they wer seperate parts)?
Chuck
#8 Posted : Monday, June 29, 2009 7:38:57 PM(UTC)
We are talking about the control panel (#1 on the diagram)
RockDawg
#9 Posted : Monday, June 29, 2009 7:41:51 PM(UTC)
RockDawg
Thanks! AP3131725 for the black then.
I wished someone had warned me about using that dang self-clean feature. This is a great and helpful forum.
#10 Posted : Monday, June 29, 2009 7:48:25 PM(UTC)
You are welcome. Unfortunately this is probably the most common problem for those ovens.
Keep us posted.
2 Pages12>
