dkarten
#1 Posted : Sunday, December 30, 2007 4:04:21 PM(UTC)
dkarten
My Maytag top loader was leaking, I diagnosed bad tub seal, got the correct part & spanner wrench, r&r the old seal, on reassembly I can't seem to get tub installed properly, have done several loads, no leak, but vibration/contact tub seems to not be aligned, installed incorrectly? any advice?
#2 Posted : Monday, December 31, 2007 3:43:39 AM(UTC)
Make sure each tub support spring is the same length as before. Also, check the feet to make sure they are all touching the floor.
dkarten
#3 Posted : Monday, December 31, 2007 5:31:58 AM(UTC)
dkarten
springs were not touched,spanner nut rests directly on tub, which is hard to center, I can see it turn unevenly, the new seal was updated,as far as I know I reassembled correct, does anyone have a parts schematic?
#4 Posted : Tuesday, January 1, 2008 12:34:22 PM(UTC)
You need to loosen the tub nut and re-adjust tub to center it.
