cappuccin
#1 Posted : Saturday, June 27, 2009 10:50:27 AM(UTC)
cappuccin
My 80 yr old Mom has a GE refrigerator model #GSH22JFRE WW that was purchased in 2005 and it makes a clicking noise from the back bottom area that is directly behind the freezer. I believe this may be where the compressor is. Now the refrigerator/freeze have no cooling ability. What could be causing this problem? I saw some other thread and your responses and most of the time it seem that it was the main board. If this sounds like the same problem is her refrigerator covered for the charge of $100.00 with GE? Do you have the 800# for GE?
Thank you so much!
woodchuckie
#2 Posted : Saturday, June 27, 2009 1:58:04 PM(UTC)
woodchuckie
Part 801 on diagram 8 is your motherboard. It's a little higher than the compressor. Could be the compressor relay gone bad that's clicking. Part 733.
Check relay here>Refrigerator Repair Guide: How To Test the Compressor Relay - ACME HOW TO.com
cappuccin
#3 Posted : Sunday, June 28, 2009 10:45:47 AM(UTC)
cappuccin
Thank you so much for your help. I will pass this info on to my brother so he can check it out for our Mom.
Kenmore Refrigerator Freezer Side By Side (Refrigerator & Freezer Repair)
by mchwalowski 11/28/2007 1:21:03 PM(UTC)
