ajax5777
#1 Posted : Sunday, June 28, 2009 8:44:17 AM(UTC)
ajax5777
howdy all, my jenn air glass stovetop, about six years old, has a dual element on the front right side. it started intermitantly not heating/glowing but now does not heat at all, on either element. sounded like a bad switch to me because how could both elements possibly quit working at the same time. after troubleshooting the system the best i could i have found that there is good power going into the switch and good power coming out so it looks like a bad dual element. my question is, is there anything else that could cause this before i buy the second most expensive part on the whole stovetop? what is the 'limiter' and could it cause this and is it replaceable seperately? is there a fuse under the glass? also, on this websites parts section for this element, it list two dual elements, one i think is called a assembly. the p/n's are ap4008877 and the other is ap4097429. one is almost $100 the other is about $70, what is the difference? thanks in advance. jason.
Dan O.
#2 Posted : Sunday, June 28, 2009 12:23:25 PM(UTC)
Dan O.
Quote:
is there anything else that could cause [the whole dual element to n/w at all]
If the switch is sending power to it, just the element, its limiter or the wiring between the switch and it.
It is a safety protector on the elemnt.
Not on your model, no. If it was defective the whole element would have to be replaced (which comes with a new limiter installed on it).
LINK > Jenn-Air JEC8430ADS Dual Element & Limiter
LINK > Jenn-Air JEC8430ADS Dual Element & Limiter (serial # 11...+)
Which one yours takes depends on the serial number of the range.
There isn't usually, no.
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
