wayne hrynyk
#1 Posted : Wednesday, June 24, 2009 8:17:04 AM(UTC)
wayne hrynyk
performed a self cleaning and everything worked fine.
Next time I tried the oven, you could select broil, bake etc but the oven would not start. The oven indicates it was working but it does not.
I pulled the oven out and now there is no indication at all.
Checked for 240volts at terminal block and all is good.
Unfortunately there is no wiring diagram with the unit.
I bought this unit brand new.
Any ideas???
Dan O.
#2 Posted : Wednesday, June 24, 2009 11:18:32 AM(UTC)
Dan O.
Quote:
Model Number: kebs107dw1
That model number appears to be incomplete (eg. kebs107dw__1).
Did you look inside the control console? That is a common location for it.
Assuming your appliance's model number is KEBS107DWH1, you can download a PDF copy of the wiring information at the following link:
LINK > Whirlpool KEBS107DWH1 'Tech Sheet'
The oven elements look to be fused or safety protected with a thermostat. The only one I see listed in the parts list is linked below.
LINK > KitchenAid KEBS107DWH1 Safety(?) Thermostat
If such a device was open, it could prevent all elements from heating but not affect the rest of the appliance's apparent functioning.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
wayne hrynyk
#3 Posted : Wednesday, June 24, 2009 1:51:51 PM(UTC)
wayne hrynyk
Dan O
I have relooked at the model number and you are correct it should be dw1
also so you know i am in Canada so the model starts with a Y.
I also talked with whirlpool and they advise me that it may be dwh1--the wh stands for white which would make sense.
I will look at the thermostat you suggest.
I did look inside the covers but no wiring diagram seems to be hidden there.
Dan O.
#4 Posted : Wednesday, June 24, 2009 11:26:55 PM(UTC)
Dan O.
That is not what I said it should be. That is what you originally posted.
You didn't supply that when you posted the model number.
Hopefully your model has one because the wiring diagram I looked at isn't for a model starting with a "Y".
Good luck!
Dan O.
www.Appliance411.ca
=D~~~~~~
wayne hrynyk
#5 Posted : Friday, June 26, 2009 3:03:03 PM(UTC)
wayne hrynyk
Hi Dan O
Sorry for misleading you.
When I had talked with the manufacturer they advised me that the Y did not mean anything except that it was sold in Canada.
I did find the thermostat and it was dead. Changed it but the control panel is still dead.
The complete model # is
YKEBS107DW1
Dan O.
#6 Posted : Friday, June 26, 2009 6:39:45 PM(UTC)
Dan O.
It is always best to supply exactly what information is listed on the appliance's identification tag. That's why it's there.
No lights or anything???
Dan O.
www.Appliance411.ca
=D~~~~~~
wayne hrynyk
#7 Posted : Sunday, June 28, 2009 4:07:43 PM(UTC)
wayne hrynyk
Dan O
Found the problem the white neutral wire became disconnected in the box.
The unit is hard wired and I suspect when I lifted it out I pulled on the wiring harness and the neutral became disconnected
I reconnected and all works perfectly. It was the thermostat.
Thanks Dan O I appreciate your help
Dan O.
#8 Posted : Monday, June 29, 2009 10:05:26 PM(UTC)
Dan O.
Quote:
Found the white neutral wire became disconnected in the box. I reconnected and all works perfectly.
Glad to hear it. Thanks for the follow up. UserPostedImage
Dan O.
Happy Thanksgiving!! The oven is dead!! (Oven Repair (including Ranges and Cooktops))
by cpfb 11/24/2011 9:06:37 AM(UTC)
KitchenAid Oven is Dead (Oven Repair (including Ranges and Cooktops))
by texanokie 12/9/2008 8:03:47 AM(UTC)
