Eric Nelson
#1 Posted : Friday, June 26, 2009 12:43:03 PM(UTC)
Eric Nelson
Our front loading HE3 washing machine makes a very loud noise when the fast spin cycle is in place and sounds like a jet engine taking off. It also seems to vibrate a lot more than before during the fast spin cycles. It completes the cycle and all else is fine. I wonder if it is bearings or something rubbing inappropriately. Any suggestions?
#2 Posted : Saturday, June 27, 2009 5:17:27 AM(UTC)
Sounds like bad tub bearings, a big repair job. If you where using the special HE degergent, check your warranty, might be covered.
An overheating motor and over 3 amps current draw would confirm this, or a simple turning the spin basket and checking for "rough bearings".
Contunued running will burn out the motor control board.
Eric Nelson
#3 Posted : Saturday, June 27, 2009 11:41:17 AM(UTC)
Eric Nelson
What do you mean cost wise by big repair job? Am I better off replacing it? We use the HE soap but don't have any extended warranty. When I spin the basket myself I don't hear anything unusual.
#4 Posted : Saturday, June 27, 2009 2:00:53 PM(UTC)
I checked a few of these and had trouble fealing "rough" bearings, but a current check confirmed bad bearings.
For this washer, it would be a $300- $500 repair job assuming just bad bearings. Fortunately, these are built better than the Frigidairs.
very noisy washer at dryer cycle (Washer Repair)
by awalle 6/28/2009 11:15:21 AM(UTC)
