5 Pages<1234>»
#11 Posted : Friday, December 28, 2007 4:39:12 PM(UTC)
Post the model number on the forum.
#12 Posted : Saturday, December 29, 2007 2:39:07 AM(UTC)
Post your model # and click on it!
Neal
#13 Posted : Saturday, December 29, 2007 6:19:26 AM(UTC)
Neal
66516959000
I took the themostat off. I checked it with my multimeter. I get 0 ohms. Does that mean its opened or closed? And is that correct? Or is this the faulty part?
#14 Posted : Saturday, December 29, 2007 8:56:03 AM(UTC)
Heater thermostat is supposed to be closed at room temperature. Check your heater.
Neal
#15 Posted : Saturday, December 29, 2007 9:48:48 AM(UTC)
Neal
I got a reading of 0 ohms
joyfulljoy
#16 Posted : Saturday, December 29, 2007 10:05:59 AM(UTC)
joyfulljoy
I have the same problem with my clean light flashing 7 times. I have no tech sheets and no scrub or energy saver buttons to push. the model number is 66516032401. Any suggestions? Thanks!
#17 Posted : Saturday, December 29, 2007 1:42:34 PM(UTC)
Just press similar buttons, usually side by side.
#18 Posted : Sunday, December 30, 2007 7:45:18 PM(UTC)
Hi Neal
Did you remove at least one wire from the heater before testing the resistance?
If not - you got a wrong reading.
If yes, then the heater is bad and has to be replaced.
In order to find the right part number for the heater I need to know if the tub is made of plastic or stainless still.
Happy New year!
Neal
#19 Posted : Monday, December 31, 2007 5:32:35 AM(UTC)
Neal
No I didn't Gene. I will do that and let you know. Thanks
Neal
#20 Posted : Monday, December 31, 2007 6:48:50 AM(UTC)
Neal
12.8 ohms with both leads off of heater
Guest (7)
5 Pages<1234>»
