All four stove top burners work but the oven touchpad does not work. No errors displayed, clock is working but can not set the time. Reset the power with no change.
just curious, was this after a self cleaning cycle ?
Yes it was the day after a self cleaning cycle.
are you ok with disassembling the clock / touch pad ? check all connections to / from clock / touch pad and make sure nothing is broken.. strange there are no fault codes though... does any button give a response at all ?
Checked all connections, all good. Can hold Bake and broil and get into the settings mode, can also enter the "show room" mode, clear button beeps but nothing else. Thanks,
Jim, Is there anything else I should check? Self cleaning switch or lock perhaps? J
sounds as if there is a bad connection or a comm error .. tried removing touch pad cable ( power down then power back up again and see if there is any fault that comes up ? )
Pulled the touchpad and controll board out checked all connections, did a resistance check on the touchpad and everything reads what it should according to the scat in the stove but between pins 5 and 9 on the ribbon cable I read a short. Five and nine do not equate to any number but could they be messing things up? Still no error codes. Thanks again, Jason
Most likely the key panel is shorted out and has to be replaced. - The part number for the black key panel is AP3205170 Good luck. Gene.
