AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer doesnt spin all i hear is buzzing and the smell of smoke
Our washer has the following problem. Here are the symptoms: -Washer does not spin but it does pump water -The drive belt is slipping and burning -I removed the agitator (the plastic part in the middle of the tub) and there was nothing jammed in there. -i put a new belt on and no change -when i took off belt and ran it the drive motor spun
Follow-up question: Is this part serviceable? Is it an all or nothing
where can i find it i have a magic chef electric washer and the only number i found under the hood isnt popping up anywhere
Remove belt and try to find cause of jam. Turn pump pulley and tranny pulley both ways. If jammed in spin direction you might have something caught in tub.Shine a light in tub and check for something. If everything is ok, you just might have the wrong belt. Washer belts are made to act as a clutch, ie. the wrong belt will cause problems like this.
did you figure it out? I have similar problem with my frigidaire washer,exact symptoms
my washer is having similiar issues. the belt squealed , then smoked and smelled and now i cant move the agitator
Did you find out what was wrong with it, I am having the same problems and would like to know how you fixed it??
Originally Posted by: richappy  Remove belt and try to find cause of jam. Turn pump pulley and tranny pulley both ways. If jammed in spin direction you might have something caught in tub.Shine a light in tub and check for something. If everything is ok, you just might have the wrong belt. Washer belts are made to act as a clutch, ie. the wrong belt will cause problems like this. :):D Awesome advice! I have a GE stackable washer/dryer combo that had this exact problem! Burning smell, tub wouldn't move. For my job I use small screwdrivers that can clip in my pocket like a pen. One had jammed in the tub!:o Better job checking my pockets from now on. My unit is ~ 15 years old. The belt now looks glazed and just generally old. Since I have the washer open I think I will order a replacement belt. Is this a good idea? Seems like I'm due. Thanks, Chris
For the Frigidaire washer, they have a sad history of partially or fully jamming of the tranny, just check.
Washer Repair
