gap
#1 Posted : Sunday, June 21, 2009 9:14:08 AM(UTC)
gap
the washer spins and turns the pulley but the pulley just spins and doest spin the tub.
sidfink43
#2 Posted : Monday, June 22, 2009 12:27:36 PM(UTC)
sidfink43
Ouch
If it is not making any noise and the motor and drive pulley are spinning freely the problem is likely in the transmission.
Here is a service manual you can look at to see if you want to attempt a repair, but given the complexity of that you may want to look at a new washer.
http://www.servicematters.com/m...ary/docs/RS3100004R1.pdf
Good luck, let us know what you decide.
gap
#3 Posted : Monday, June 22, 2009 7:00:35 PM(UTC)
gap
Originally Posted by: sidfink43 Go to Quoted Post
Ouch
I guess what your telling me is that the pulley has nothing to do with the spin cycle? If so I guess I'll look at another washer. I'm sure a transmission is expensive.
sidfink43
#4 Posted : Tuesday, June 23, 2009 11:56:15 AM(UTC)
sidfink43
I think that is my conclusion, and if you look at the trouble shooting on page 3-5 of the manual that appears to be the conclusion. Since it agitates it would appear the pulley is attached correctly and so it is not likely your problem.
Sorry not to have been of more help, good luck with a new machine.
GE Washer no spin or agitate (Washer Repair)
by suniack 12/18/2017 7:09:50 PM(UTC)
Kenmore 800 Washer no spin on delicate cycle spins fine on others (Washer Repair)
by tedalb 3/27/2017 7:29:52 PM(UTC)
GE profile washer no spin or agitate (Washer Repair)
by OlneyJeeps 11/22/2014 2:47:18 PM(UTC)
Please Help..washer No Spin (Washer Repair)
by rnhib@att.net 3/12/2013 5:00:40 PM(UTC)
Kenmore washer No spin no rinse parts source (Washer Repair)
by mkc1962 11/10/2012 6:40:20 AM(UTC)
Top load washer NO SPIN - help me diagnose whether brake, upper/lower bearings (Washer Repair)
by rlpenny 5/9/2012 6:08:22 AM(UTC)
GE washer no spin cycle (Washer Repair)
by fsuglover 4/8/2012 4:41:33 PM(UTC)
maytag washer no spin (Washer Repair)
by phil feeley 1/6/2012 11:40:56 AM(UTC)
Neptune washer NO SPIN (Washer Repair)
by shelvar2 7/10/2011 11:10:24 PM(UTC)
Maytag Washer no spin at final spin and 3E keeps coming up (Washer Repair)
by chanchar 6/25/2011 11:11:44 AM(UTC)
GE washer no spin (Washer Repair)
by larry.blythe 6/11/2011 9:50:16 PM(UTC)
washer no spin on low water set. (Washer Repair)
by mtokas 4/12/2011 4:31:43 AM(UTC)
GE Washer No Spin For Larger Loads (Washer Repair)
by ACEMANNW 4/10/2011 10:42:31 AM(UTC)
Whirlpool Washer No Spin or Drain (Washer Repair)
by sheetscomm 2/23/2011 8:56:41 AM(UTC)
Kenmore Washer No Spin No drain (Washer Repair)
by cmarshall3 1/10/2011 5:20:20 AM(UTC)
