karenhudson
#1 Posted : Monday, June 7, 2010 10:57:25 AM(UTC)
karenhudson
my GE profile top load front-access washer will not agitate or spin. i checked the belt and it is not broken or off track. the lid switch seems to still be working. can you help me determine what part may need to be replaced and whether this is a do-it-yourself job.
sidfink43
#2 Posted : Wednesday, June 9, 2010 7:13:48 AM(UTC)
sidfink43
I cannot get your exact model number to come up, but it looks like this is a GE washer with a diagnostic built into the inverter on the motor. You will know this is the case if you have a flashing light on the motor.
The first place you want to check is the lid switch and the fuse if you have one, but before doing even that clear out the inverter codes. Use this site,
HydroWave GE Washer Repair Guide
to see how to do that.
If that does not do things, check the lid switch and fuse and also see if you are getting an error code from blinking lights. This will tell you the likely problem, which if all else checks out could be the mode shifter.
GE washer won't spin, smells like burning rubber (Washer Repair)
by TimBlock 12/27/2015 12:35:03 PM(UTC)
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 12/21/2015 10:19:03 AM(UTC)
GE washer won't spin during final rinse (Washer Repair)
by Asu19 10/28/2015 2:38:21 PM(UTC)
GE Washer won't spin or agitate (Washer Repair)
by whovian2015 9/30/2015 2:56:35 PM(UTC)
GE washer won't spin (Washer Repair)
by Dana021 4/28/2014 5:05:18 PM(UTC)
GE Washer Won't Spin - Lid Lock Error? (Washer Repair)
by lum 1/30/2014 11:41:30 PM(UTC)
GE Washer won't spin dry clothes (Washer Repair)
by jglascoe1691 12/10/2013 4:41:11 AM(UTC)
GE washer won't spin/agitate (Washer Repair)
by Mlsmith 10/8/2013 5:30:10 PM(UTC)
GE washer won't spin or agitate (Washer Repair)
by unclejohnforever 2/27/2013 6:58:56 AM(UTC)
GE washer won't spin - Mark (Washer Repair)
by masavrin@netzero.net 1/2/2013 9:45:50 AM(UTC)
by the5tjrs 11/2/2012 9:01:04 AM(UTC)
GE Washer won't spin with heavy loads (Washer Repair)
by paulgj 10/18/2012 8:00:50 PM(UTC)
ge washer won't spin (Dishwasher Repair)
by magsw 5/24/2012 3:12:19 PM(UTC)
ge washer won't spin or wash, no blinking lights on motor (Washer Repair)
by fr45 2/28/2012 9:22:19 AM(UTC)
GE Washer won't spin but agitates (Washer Repair)
by guptamgs@hotmail.com 1/5/2012 11:29:15 AM(UTC)
