lentz1205
#1 Posted : Monday, November 7, 2016 7:41:33 AM(UTC)
lentz1205
I just put in a new clutch assy, and a new direct drive motor coupling, also got into the transmission and had to realign the gears after I messed them up. put it all together and hooked it up to see if it would spin and it did, that was the main problem with it. so I hooked it up, let it pump some water in and checked to see it it would drain and spin ok, it did fine, so I set it to do a cycle and when it got full of water and went to agitate it didn't do anything. just starting making a humming noise, like the motor wants to turn but won't. now it won't do anything, drain,agitate,or spin. just hums. any ideas out there on what I need to do. thanks:confused:
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
Whirlpool Washer does everything, but RINSE - even after new parts (Washer Repair)
by nryuhasz@hotmail.com 5/26/2022 7:09:28 AM(UTC)
Whirlpool Washer Stuck in Drain Mode (Washer Repair)
by Greg72 2/15/2022 1:07:03 PM(UTC)
