Greetings, I have a Maytag washer model MVWC200XW2, it will go thru all cycles till it gets to end of spin, then it goes back and start washing again, never completes the cycle, any help? THANKS!
These models are incredibly unreliable as you now know. Since it completes a cycle without any problem that suggests the control unit is the problem. But even if it is, this part here, Part number: AP5645952
is expensive and you may just want to replace it with a good no frills no electronics top loader. If you do decide to try and repair it and by the control unit from this site you can return it if it does not fix the problem.
