2 Pages12>
CHFCOOK
#1 Posted : Tuesday, August 14, 2007 8:09:25 PM(UTC)
CHFCOOK
Washer Wont Fill Wth Water, I Know Its A Fuse But I Dont Know What Kind Or Where It Goes.
#2 Posted : Wednesday, August 15, 2007 9:33:25 PM(UTC)
CHFCOOK
Unplug the power cord. Remove three screws on top of the control panel and open it. In the middle you'll see the bracket with the fuse and the switches. It's a regular fuse and you can buy it in any electronic or electric parts store.
Also check the lid switch and the "check" switch. They should work as shown on the wiring diagram:
UserPostedImage
- Here are the break down diagrams for the Maytag washer Model LAT8035AAE
Good luck.
CHFCOOK
#3 Posted : Thursday, August 16, 2007 1:53:16 PM(UTC)
CHFCOOK
Ok, Thata Is Good Information. Now, How Do I Get Into The Washer To Change The Fuse Or Lid Switch
#4 Posted : Thursday, August 16, 2007 2:55:33 PM(UTC)
CHFCOOK
Unplug the power cord. Remove three screws on top of the control panel and open it. In the middle you'll see the the bracket with the fuse and the switches. It's a regular fuse and you can buy it in any electronic or electric parts store.
- - Here are the break down diagrams for the Maytag washer Model LAT8035AAE
Good luck.
gardenladymg
#5 Posted : Sunday, October 14, 2007 9:28:06 PM(UTC)
gardenladymg
Don't know how to post new message: Is there a way to get schematic for this washer too? It won't start. Lid switch power side tests good, but other side questionable. Not sure if fuse or switch or ?
THanks
#6 Posted : Sunday, October 14, 2007 10:49:15 PM(UTC)
Hi gardenladymg
It is very simple to post a new message. Just register on the forum an you can post it.
The wiring diagram for your washer suppose to be inside the control panel.
If it's not there you can view one attached to this reply.
- The part number for the new lid switch AP3159413
- Here are the break down diagrams for the Maytag washer Model LAT9360AAE
Good luck.
File Attachment(s):
lid switch.doc (61kb) downloaded 100 time(s).
skalesplitur
#7 Posted : Monday, December 7, 2009 12:52:12 PM(UTC)
skalesplitur
Hello,
I also have this model of dryer, and the fuse keeps blowing when I open the lid.
Does this mean I need a new lid switch, or do I have a short somewhere?
#8 Posted : Monday, December 7, 2009 2:14:12 PM(UTC)
I'm assuming "dryer" is mistyping and we are talking about washer.
Quote:
...Does this mean I need a new lid switch, or do I have a short somewhere?...
You have to test the lid switch for continuity to figure out if the problem is there or somewhere else.
Guest
#9 Posted : Tuesday, December 20, 2022 6:44:01 PM(UTC)
Guest
Rank: Guest
United States
My maytag mvwx500xw2 threw and shredded the drive belt. I was able to replace that, but now the washing machine will only run one load after recalibrating. The second load does not spin or drain properly, any suggestions?
Edited by user Tuesday, December 20, 2022 6:45:25 PM(UTC)  | Reason: Typo
Guest
#10 Posted : Sunday, January 28, 2024 8:02:39 AM(UTC)
Guest
Rank: Guest
United States
Does anyone know if a pedistal for a matag series 4000 washer work on a new matag washer?
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
2 Pages12>
