water not draining before spin cycle. I have bypassed lid switch, no help. The motor shaft that the drain pump fits onto IS NOT turning when the machine should be draining, therefore I don't believe it is the pump. The drain line is not clogged. I'm thinking it is the timer. Is there any way to check it? Any other suggestions? Thanks
Groups: Expert
Ordered the timer from y'all and machine does the same thing. After it agitates and before it spins, it is suppose to drain most of the water out,correct?:confused: Can I return the timer? Any other suggestions?
Groups: Expert
Yes, you may return the timer. Maybe I'm not understanding your symptoms. In normal cycle, agitation should begin in high speed. Last 6 minutes of agitation should be in low speed. Then motor stops for 25 seconds. Motor then starts again for drain only for about 2 minutes and then stops again for about 15 seconds and then starts again for spin/drain. If when motor starts directly after agitation it drains/spins simultaneously, then the neutral drain mechanism in the gearcase is not functioning properly.
Eric
Just my 2 cents but an old drain hose can kink, you won't drain with a kink.
Groups: Expert
Thanks for the help. The kit looks like it would be over my head and the gearbox is more $ than I want to put into the washer. Guess I'll just live with it.
