Hi,I replaced the clutch on my GE washer model EWA2000A0WW thinking it would fix the problem. It washes just fine and it pumps the water out but when it needs to spin the motor does but the washer doesn't . Thank you.
Does the transmission pulley turn in spin mode. If so, the transmission is probably at fault. If not, unplug the machine and see if you can turn the transmission pulley in the spin direction by hand. If it turns then see if the clutch is working correctly.
