With any cycle, it fills with water and then clicks off. It does not agitate. If we manually forward it to a later part of the cycle such as rinse or drain, it will no perform those either.
We disassembled and reassembled the agitator, checked the pumps and hoses and found no obvious issues. Any suggestions?
Groups: Expert
Remove the cabinet and unplug the motor connector. Check for corrosion on the pins or burnt/broken wires. Also check the two connections on the motor thermal overload switch for the same thing.
Do you hear any noise from the motor when it should be agitating or drain/spinning? Does the timer advance on it's own after tub is full of water or you have it in spin mode?
Eric
Found no corrosion or burnt/broken pins or wires. Do you hear any noise from the motor when it should be agitating or drain/spinning? Just now, it filled with water and agitated, it even sounded like it began the next cycle, but then it stopped shortly after it started. The timer did not advance. I manually moved it ahead to the Spin cycle and while I hear clicking noises, nothing happens. Read more: http://forum.appliancepartspros...p;p=827491#ixzz2dVBDC53F http://forum.appliancepartspros.com
Groups: Expert
Sounds like an open neutral problem. Neutral from power cord comes in on the white wire at motor connector which jumps to the thermal overload switch, other side of switch goes to motor windings and back out of motor connector on white/black wire to timer. Double check those connections on the motor overload. Do continuity checks on it. Faulty timer is another possibility. Use the wiring diagram and make some continuity checks to find where your losing power.
Eric
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin
(Washer Repair)
by Guest
5/13/2023 11:34:56 AM(UTC)
Maytag washer spins but won't agitate
(Washer Repair)
by salconflu
4/27/2022 6:06:43 PM(UTC)
maytag washer mvwc465hw3 won't agitate
(Washer Repair)
by Guest
11/22/2021 2:54:31 PM(UTC)
Washer won't agitate or spin out.
(Washer Repair)
by tracibailey
1/11/2019 8:43:20 AM(UTC)
Washer won't agitate, spin, drain, but motor runs
(Washer Repair)
by dmbailey0321
6/26/2018 11:36:55 AM(UTC)
LAT2500AAE will spin,rinse,and drain but won't agitate
(Washer Repair)
by jlh72
1/18/2018 5:39:10 PM(UTC)
Kitchen Aid Washer Won't agitate or spin
(Washer Repair)
by M Yaworski
7/18/2017 7:00:37 AM(UTC)
Washing machine won't agitate, will spin though
(Washer Repair)
by Freddy76
7/17/2017 4:05:56 PM(UTC)
Kenmore 110-92573200 won't agitate, but spins and advances
(Washer Repair)
by LallyCollins
3/5/2017 9:44:00 AM(UTC)
Whirlpool Washer Won't Agitate/Spin
(Washer Repair)
by Shazaam
9/1/2016 2:47:46 PM(UTC)
Whrilpool Cabrio won't agitate
(Washer Repair)
by Harvey E.
7/27/2016 11:58:40 AM(UTC)
GE Washer fills & drains, but won't agitate or spin
(Washer Repair)
by bonerjamz03
1/10/2016 6:17:17 PM(UTC)
Washing machine won't agitate, drain, etc.
(Washer Repair)
by rhinkley
12/17/2015 2:44:46 AM(UTC)
Won't agitate, will spin
(Washer Repair)
by brewbarn
11/3/2015 10:48:46 AM(UTC)
Washer won't agitate or spin, and motor won't turn
(Washer Repair)
by Jimmm59
8/24/2015 9:59:30 AM(UTC)
