Just replaced Water Inlet Valve and Water Temp Control Switch, control setting is only working on hot/cold and warm/warm, no cold/cold only setting when button is pushed.
Use a meter to see if 120v is getting to the cold terminal connector on the water inlet valve when the temp is set for cold-cold. That will tell you if the problem is in the temp selection switch or the valves.
