I tried everything that was on my response list for my agitator issue. The agitator and gear on the shaft are ok. The inside shaft that drives the agitator spins freely, but the end play is about 3/8"+/-. Also on the bottom of the assembly the agitator shaft turns with belt movement, but not the area from the transmission up. The belt looks good but slight slack. The llarge pulley appears bent and the idler/tensioner stays engaged at all times. Anymore ideas, or is my 3 yr old unit trash? I cannot :confused:afford another set or an washer at this time. Thank you for all your help thus far!!!
