I need to replace the rubber seal on my front load washing machine. If I order a gasket (ap4334050) will this be everything that i need?
Hi Tonya Make sure you have the wire and spring that holds the gasket on. You should be able to use the old one from your machine. This is a job which will require some patience and I suggest a helper. GE tenanciously guards their tech documents, but there is a GE service manual which has a good set of instructions and pictures, and here it is from another Forum (hopefully they won't mind). http://appliancejunk.com/ge/washer/31-9135.pdfGood luck
