| » maytag washer |
Model Number: sav405deww Brand: Maytag Age: 1 - 5 years
washer fills and washes but doesnt go into spin drain cycle ,,,you have to manual turn control knob to spin then pull out again ,,after that it works ,,but i have to manual turn to spin after every load ,,,could this be timer switch ? if so how do you replace it ? besides pulling off back cover are there any tips for replacing timer ,which is what i think it is ,,,thanks steve Norwood Pa
Yes it could be a faulty timer.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
The timer was bad. The only couple tricks to replacing timer is prying off the inner cap on timer knob. Once you get that off. Pry and pull white inner locking cap. Reach around back after you unplug timer connection and remove screw. Grasp timer slide it to side and it will pop up and off Place new timer into same spot. And slide it the opposite way. Replace screw plug in connections. Put cover back on washer and plug back in. The way i knew it was the timer was washer. Not going into spin cycle after wash is done washing. I manually had to spin knob to spin and turn back on.
| Display Modes | |
| stackable Maytag Washer/Dryer-washer no go | robertcardelli | Washer Repair | 1 | 02-03-2012 06:20 PM |
| Maytag Washer | Clayc | Dryer Repair | 2 | 01-24-2011 03:22 AM |
| help how do you speciffically replace washer timer on Maytag washer | stupid1 | Washer Repair | 5 | 07-04-2009 05:21 PM |
| maytag washer/dyer combo washer no water | lindavanzandt | Washer Repair | 0 | 11-30-2008 08:35 AM |
| maytag washer | catwood | Washer Repair | 1 | 01-12-2008 01:38 AM |
